Evaluate diameter full 360-degree circle and 180-degree semicircle.
Calypso uses some hidden formulas to get that, but it depends on used evaluation method.
I wonder how you on ASME are handling circles/cylinders/cones on less than 180°deg
By UF you mean United Feature? I would recall points into one feature.
For ISO is used Gauss - so no problem with calculation, but for ASME - IT/OT can not be done on less than 180°
I am the one who asks ASME people how they do it 🙂
I measured diameter of Can (UF x2 Ø67mm) from a center reference using two semicircles (10° ~ 170° , & 190° ~ 350° ) due to grooves but reported 3 different diameters:
• 1st based on full circle (both semicircle),
• 2nd based on top semicircle ( 10° ~ 170° )
• 3rd based on bottom semicircle ( 190° ~ 350° ).
I noted that the full circle diameter was smaller (approx: 0.200mm) than both semicircles. I also noticed both semicircle centers are out from the center (concentricity higher than full circle).
What is best way to report (UF x2 Ø67mm) callout.
Thank you
If it's UF, then you should report one measurement of complete circle using both semi-circles - Without UF you would have two separate circles divided by groove/s
