[K...] Posted November 23, 2023 Share Posted November 23, 2023 How calypso evaluate diameter of full 360-degree circle and 180-degree semicircle. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 23, 2023 Share Posted November 23, 2023 Calypso uses some hidden formulas to get that, but it depends on used evaluation method. I wonder how you on ASME are handling circles/cylinders/cones on less than 180°deg Link to comment Share on other sites More sharing options...
[K...] Posted November 23, 2023 Author Share Posted November 23, 2023 Thank you Martin: May I know how to report UF x2 Ø67 callout, and how to handling less than 180°deg. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 23, 2023 Share Posted November 23, 2023 Please sign in to view this quote. By UF you mean United Feature? I would recall points into one feature. For ISO is used Gauss - so no problem with calculation, but for ASME - IT/OT can not be done on less than 180° I am the one who asks ASME people how they do it 🙂 Link to comment Share on other sites More sharing options...
[K...] Posted November 23, 2023 Author Share Posted November 23, 2023 I measured diameter of Can (UF x2 Ø67mm) from a center reference using two semicircles (10° ~ 170° , & 190° ~ 350° ) due to grooves but reported 3 different diameters: • 1st based on full circle (both semicircle), • 2nd based on top semicircle ( 10° ~ 170° ) • 3rd based on bottom semicircle ( 190° ~ 350° ). I noted that the full circle diameter was smaller (approx: 0.200mm) than both semicircles. I also noticed both semicircle centers are out from the center (concentricity higher than full circle). What is best way to report (UF x2 Ø67mm) callout. Thank you Link to comment Share on other sites More sharing options...
[Ma...] Posted November 23, 2023 Share Posted November 23, 2023 If it's UF, then you should report one measurement of complete circle using both semi-circles - Without UF you would have two separate circles divided by groove/s Link to comment Share on other sites More sharing options...
[K...] Posted November 23, 2023 Author Share Posted November 23, 2023 Thank you very much Link to comment Share on other sites More sharing options...
[K...] Posted November 23, 2023 Author Share Posted November 23, 2023 But it is UF x2 (what is x2 means) Link to comment Share on other sites More sharing options...
[Ma...] Posted November 23, 2023 Share Posted November 23, 2023 I am not sure - haven't seen a drawing nor a part, so my guess is limited. Link to comment Share on other sites More sharing options...
