[Ca...] Posted November 21, 2023 Share Posted November 21, 2023 Hey all, I'm being asked about exporting data or creating a report in a way so it can be imported into Solidworks Inspection. See attached for an example file I've been given. Up until now I've just used PiWeb PDF's. Can someone point me in the right direction on creating a TXT doc like this?Untitled.png Link to comment Share on other sites More sharing options...
[Cl...] Posted November 21, 2023 Share Posted November 21, 2023 That looks like a chr text file. This is generated every time you run your measurement plan. Only after you tick on the Table File. (Resources > Results to File). chr/fet/hdr results located here. C:\Users\Public\Documents\Zeiss\CALYPSO 7.0\workarea\results Link to comment Share on other sites More sharing options...
[An...] Posted November 21, 2023 Share Posted November 21, 2023 Good Morning Casey, I hope this message finds you well. Please see below links. https://portal.zeiss.com/knowledge-base ... &id=445103 https://portal.zeiss.com/knowledge-base ... &id=445483 Thanks! Link to comment Share on other sites More sharing options...
[Ca...] Posted November 21, 2023 Author Share Posted November 21, 2023 Thanks Clarke, that's exactly what I needed! Link to comment Share on other sites More sharing options...
