[Xi...] Posted November 20, 2023 Share Posted November 20, 2023 see attached pic. current version calypso 6.8 folder is not at: C:\Users\Public\Documents\Zeiss. how to re-install it?6.8 missed.png Link to comment https://qualityforum.zeiss.com/topic/6806-current-version-folder-missed/ Share on other sites More sharing options...
[Ri...] Posted November 20, 2023 Share Posted November 20, 2023 When you run Calypso from that folder, which version is running? Link to comment https://qualityforum.zeiss.com/topic/6806-current-version-folder-missed/#findComment-27596 Share on other sites More sharing options...
[Xi...] Posted November 20, 2023 Author Share Posted November 20, 2023 version 6.8 Link to comment https://qualityforum.zeiss.com/topic/6806-current-version-folder-missed/#findComment-27598 Share on other sites More sharing options...
[Ri...] Posted November 21, 2023 Share Posted November 21, 2023 I have seen this before where the newest install was simply named Calypso. Link to comment https://qualityforum.zeiss.com/topic/6806-current-version-folder-missed/#findComment-27600 Share on other sites More sharing options...
[Je...] Posted November 21, 2023 Share Posted November 21, 2023 Please sign in to view this quote. This is standard behavior for parallel installation of CALYPSO. Your newest installation may be "CALYPSO" without a version identifier. An added note to parallel installations: Do not install older versions than your current install. If you must install an older version for any reason, you should uninstall current versions and start over with the oldest version and work up towards newest. There are program files and registry keys that can be over-written by older versions installed after newer. This isn't the case in every situation but generally, this is the simplest method to prevent several errors associated with parallel installs. Link to comment https://qualityforum.zeiss.com/topic/6806-current-version-folder-missed/#findComment-27602 Share on other sites More sharing options...
