RDS Sensor Change
We have a customer with an Eclipse with 2 different Zeiss sensors and 1 Renishaw sensor. When they try to do an automatic stylus change to swap to another sensor, the RDS rotates to A90 B0, moves into position and stops. Below is the "missing file" error that pops up. They claim everything was working fine until they had a firmware update. Any thoughts?
Likely a CAA file is missing that IDs the RDS unit due to this being an Eclipse. Older firmware looked in the CALYPSO directory for the proper file SN while newer firmware versions look in the controller itself.
Call CIC for a HW ticket. HW Tech may be able to resolve remotely.
