Open/Load Measurement Plan - Windows Explorer
Having all my files organized in folders, and sub-folders, and sub-sub-folders.... I have attached a picture from within the (each) file as the "folder icon" through PROPERTIES/CUSTOMIZE...
Why do these remove, and revert back to the blank manila folder, as if never attached???
I did some trial and error... An attached photo will be removed the next time the file is opened IF that file has been moved, say from folder A to folder B... so I made sure to re-organize all folders first, then attach pictures.... but they still remove after time... Some go back to blank, others stay attached, but after you open the file, close the file, and look again, it is now blank...
Please help... Thank you!
While your question is Windows related only and has nothing to do with CALYPSO, I can point you in the direction to find the answers you seek.
Create your icon from the images you have.
https://www.thewindowsclub.com/how-to-m ... windows-10
Change the icon of the folder you wish to have a new icon for.
https://www.makeuseof.com/tag/customize-icon-windows/
