[Da...] Posted February 8, 2022 Share Posted February 8, 2022 Hello, is it possible to retrieve the calibration information from an existing measurement, when the sensor has been recalibrated since? I can generate a report with "Quality" Data or look at the Properties of the deformation series, but that does not include every parameter from the calibration as I would get when looking at the current sensor calibration information (like distances, angles, height-deviation etc). Greetings, Daniel Link to comment https://qualityforum.zeiss.com/topic/686-export-calibration-information-from-old-measurement/ Share on other sites More sharing options...
[Je...] Posted February 10, 2022 Share Posted February 10, 2022 Hello Mr. Sommer, after a new calibration the old file is overwritten. Unfortunately there is no way to get access to old calibration results. Best regards, Jens Braun Link to comment https://qualityforum.zeiss.com/topic/686-export-calibration-information-from-old-measurement/#findComment-2106 Share on other sites More sharing options...
