Issues With Curve
Per the screen shot... Why are my green scans so far off the part when compared to the yellow nominals?
Now I have not used curve in a year so I might be doing something way off base..
And also, what's the major difference in a 2D and 3D curve? Again, beena while since my training lol..
Mike
On curves, when you select "Show Measured Points", it is showing you the probe center. If you select "Show Deviations", you'll see little points that represent the actual curve.
2d curves has 1 vector that remains constant as in 1st picture below.
On a 3d curve, all vectors would be active. For example, if you generated a 3d curve from a section of your computer's mouse, all 3 vectors would be constantly changing relative to the surface of the mouse.
