Flatness and profile callout on datum surface
Does anyone know how I can check this profile call out on datum A in 7.4? I have another part for this assembly that has the same tolerance for flatness and profile. I imagine the profile call out would be redundant.
It appears you have two separate surfaces for Datum A.
Those two surfaces must be within 0.008 profile of each other.
Your Flatness is separate from the profile and is checked from both surfaces as one.
How would I do the profile call out in Calypso? I've tried profile but doesn't seem to be correct. Or I'm not using it right.
Sorry to hijack, but I'm only curious - are this small tolerance values imaginary or do you actually try to do a product on the drawing?
This is a customers part we have been making about a year. 450mm x 285mm. Linear guide carriages. There's a smaller one and larger one in this assembly with similar tolerances.
