Calculating volume from surface comparison
Dear GOM user or GOM Team,
I was wondering if I can also calculate the volume from a surface comparison analysis. In my case I have a surface without snow accumulation on my model ground and then a surface with snow on the ground. And then I did a surface comparison so see how high the snow cover was on the ground.
Kind regards
Jennifer
  • 2 years later...
Hello to everyone, I have this problem too. Could you give me a good link to understand the calculation of the integrated distance? That link doesn't work.
Thanks in advance,
Alessio
Could it be possibile to select a closed region (for example, a curve) and measure the integrated distance for that region in the surface comparison?
