[Ja...] Posted April 6, 2021 Share Posted April 6, 2021 Years ago, I used QC-Calc at another job, and they had a dashboard that showed the last 20 or so parts ran with either Green, yellow or red background. You would click on the box witht he job you are looking for and it would open the report up. Is there anything liek that in PiWeb? Link to comment https://qualityforum.zeiss.com/topic/6932-dashboard/ Share on other sites More sharing options...
[4e...] Posted April 6, 2021 Share Posted April 6, 2021 Hi Jake, PiWeb Reporting Plus has a very similar dashboard. Open up PiWeb Reporting Plus, click the inspection plan of interest in the left sidebar. Choose the Dashboard report from the right pane. Voila (page 7) Link to comment https://qualityforum.zeiss.com/topic/6932-dashboard/#findComment-28442 Share on other sites More sharing options...
[Br...] Posted May 20, 2021 Share Posted May 20, 2021 Where is Pi web getting the min max values for the statistical parameters for the line plots on page 2? Where would I go to change or set these parameters? Link to comment https://qualityforum.zeiss.com/topic/6932-dashboard/#findComment-28444 Share on other sites More sharing options...
[Ja...] Posted October 18, 2023 Author Share Posted October 18, 2023 Please sign in to view this quote. Sorry for the long delay, this fell off my radar. I don't have PiWeb Reporting Plus licenses, so I was hoping to find something that would work through Monitor. Something showing the last 20-24 parts ran, with either Green Yellow, or Red coloration, and when you click on the icon, it opened up a specific PiWeb report. Link to comment https://qualityforum.zeiss.com/topic/6932-dashboard/#findComment-28446 Share on other sites More sharing options...
[4e...] Posted October 19, 2023 Share Posted October 19, 2023 Well, without PiWeb Reporting Plus licenses, you'll only be able to view the data of the last 10 parts. But you could use a Line Plot in a Characteristic table set to Grid layout in properties to replicate the QC-calc style layout. Set the properties of the Line Plot to change the way the plots look (background colour, dot size, line colour, etc etc) Link to comment https://qualityforum.zeiss.com/topic/6932-dashboard/#findComment-28448 Share on other sites More sharing options...
[Ja...] Posted October 21, 2023 Author Share Posted October 21, 2023 The last 10 parts is fine, it will give us a real time look at how the parts are running without having to open PiWeb monitor. I plan on using a 27" monitor displaying just the Dashboard, being setup in two places. The first being the center of QA lab, and the other in the front office by the GM's office. Link to comment https://qualityforum.zeiss.com/topic/6932-dashboard/#findComment-28450 Share on other sites More sharing options...
[Jo...] Posted October 30, 2023 Share Posted October 30, 2023 Hello Jake, For this you would need at least an SBS solution of PiWeb. Reporting is only intended to be a local solution, meaning results are only visible locally at the CMM. For reporting at different locations / using dashboards you would need a network solution which sounds like it would better address what you are looking to do. Link to comment https://qualityforum.zeiss.com/topic/6932-dashboard/#findComment-28452 Share on other sites More sharing options...
