New GDT Library_Position
Running into some confusion with dissimilar results between a Position in the new GDT Library vs. the legacy Best Fit Bore Pattern
Even though I don't need to use SIM REQ because I am using a fully constrained DRF, the plotting capability is limited to one position per plot if I don't use it.
BestFitBorePattern Position_1.JPGBestFitBorePattern Position_2.JPGGDT Postion_2023_1.JPGGDT Postion_2023_2.JPG
I think I may have stumbled onto part of the problem. Unlike the legacy position, the new Position does not convert the datum features to Outer Tangential Element or apply constraints per ISO5459. I was able to change all 3 of the datum feature planes to Outer Tangential but the constraint button was grayed out. I got a little closer to the same numbers but I'm guessing the lack of the ability to apply a constraint may close the gap even further
