[Da...] Posted October 25, 2023 Share Posted October 25, 2023 Hello everyone, I am trying to set up an offline seat. When I try to start up Calypso, it gives me a Connection to Probe Database error. How do I fix that? Link to comment https://qualityforum.zeiss.com/topic/6958-offline-seat/ Share on other sites More sharing options...
[No...] Posted October 26, 2023 Share Posted October 26, 2023 Depends on what the actual error is. The error message often points you to an error log in the config folder. It has more information on what is actually happening. Some of those errors are not even caused by Calypso or the db itself, but by SQL Server. Sometimes a reboot was enough to fix it. Link to comment https://qualityforum.zeiss.com/topic/6958-offline-seat/#findComment-28614 Share on other sites More sharing options...
[Da...] Posted October 26, 2023 Author Share Posted October 26, 2023 Thank you for your response. Actually, I reinstalled Calypso and that fixed the issue. The issue was because SQL server SDCO never got installed. Not sure why that happened but its fixed now. 😃 Link to comment https://qualityforum.zeiss.com/topic/6958-offline-seat/#findComment-28616 Share on other sites More sharing options...
