Base Alignment assistance
Hi team, we have recently purchased our first Zeiss which is running Calypso 6.4. We are about to do our first test inspection but can not do our initial base alignment as the drop down box is not highlighted. Can anyone assist in telling us what we are doing wrong. We have set our CMM Tab & stylus system, both have a green light. We have picked our features on the Features Tab, Top Plane, front plane (2d line) LH (2dline). We have set our clearance plane in characteristics tab 6198_06ea19b44e9886cd93a0b2952d9b71f4.jpg
Middle column, clear existing results. Unless you have specific reasons, you probably also need to change your feature-to-feature nav dropdown to use the clearance plane, and your run mode dropdown to normal.
