[Ma...] Posted March 5, 2019 Share Posted March 5, 2019 Hello , Is there anyone that can help me out in reporting out X and Y location on final reports for true position. thank you, Matt Link to comment Share on other sites More sharing options...
[Me...] Posted March 5, 2019 Share Posted March 5, 2019 Resources->Characteristics Settings Editor->Additional Printout->Turn on Link to comment Share on other sites More sharing options...
[Ri...] Posted March 5, 2019 Share Posted March 5, 2019 Once you do that, PiWeb adds "TOLERANCES" to the coordinates. Isn't that cool!!! Tolerances on coordinates for True Position. Tolerances. 🙄 Link to comment Share on other sites More sharing options...
[Ma...] Posted March 5, 2019 Author Share Posted March 5, 2019 awesome thank you very much. Link to comment Share on other sites More sharing options...
[Ja...] Posted October 23, 2023 Share Posted October 23, 2023 Hi Thanks for this, really helped. However, is there a way of rotating my co-ordinate system so that each hole becomes zero in 'X'? Example, I'm measuring some holes on a shaft sat in the ZX plane. See attached, my nominal values for Hole1 at 12 o clock (highlighted) is 5.200" in Z (half my PCD) and then 0 in X (centre)..but as we rotate round the face measuring each hole, the nominals change to actual position related to the centre. What I'd like, is the co-ordinate system to rotate so that each hole becomes TDC, and we have the same 5.200 and 0 nominal values. Makes it easier to understand when sharing the data with customers Thanks! JackZ X Position Capture.JPG Link to comment Share on other sites More sharing options...
[Ja...] Posted October 23, 2023 Share Posted October 23, 2023 I think the only way to do that is generate a new alignment for each hole. We do that on several jobs ourselves. Usually we take the existing alignment, copy/paste, and then modify using "Special" button, It can be a pain to get all the alignments setup, and you end up with a lot of alignments depending on the part. (see pics below). Link to comment Share on other sites More sharing options...
