[Ch...] Posted September 7, 2023 Share Posted September 7, 2023 When I click on the rds-xxt rotation, the head is missing in the graphics window. How do I get this back? Missing Head.PNGFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted September 11, 2023 Share Posted September 11, 2023 Did you create a MasterProbe with Stylus System Creator and import it (SSC file)? Correct me if I'm wrong (anyone), when you import the MasterProbe as an SSC, it places the RDS Head on the unit shown. Your MasterProbe should look like the attached image. (RDS XXT shown) Capture.JPGFetching info... Link to comment Share on other sites More sharing options...
[Cr...] Posted October 20, 2023 Share Posted October 20, 2023 Charles, did you figure how to fix it? I have the same issue. Link to comment Share on other sites More sharing options...
[Ke...] Posted October 20, 2023 Share Posted October 20, 2023 In order for the RDS and XXT to show in simulation, you must add them when creating the SSC. The RDS is found under "Probe adapters" and for most cases will be the 18p version. The XXT is then found under "Sensors/probes". Once those are created, you can then add your plate, extensions, and styli as needed. It is also recommended to create a simple template SSC which just has the RDS and XXT already added, and start from that whenever a new styli is needed. Link to comment Share on other sites More sharing options...
[Je...] Posted October 20, 2023 Share Posted October 20, 2023 https://portal.zeiss.com/knowledge-base ... &id=520919 Link to comment Share on other sites More sharing options...
