2022 Calypso - Recently opened measurement plans
I have some older measurement plans that I want to put into the pinned menu in the recently opened measurement plans. Since the older programs do not show up, I have tried opening the program, saving it and it does not show up in the recently opened measurement plan. I have also noticed the dates on the ones that are there, show future dates like 8/22/22.
Has anyone run across this or have any fixes?
Thanks
Mark
Zeiss ACCURA 20/30/15
  • 1 year later...
Good Afternoon,
It has been a year plus now from original post and using the same 2022 version (7.4xx) We have the same Issue as the original post states. We use multiple programs a day and go back and forth sometimes and would like to be able to see the recently used plans.
Has anyone came up with a fix, or do we just have to live with it until we upgrade to 2024 and hope it works there??
Thanks
Thanks Jeff,
My list wouldn't refresh recently used, and pinned programs would not stay pinned. I deleted file and it seems to resolved both issues.
Thanks Jeff for the info!
John, Thanks for your response as it helped fix our problem as well. All is good now!
Thanks for the information. I have been dealing with this for a long time. I wasn't sure what happened. It used to work fine. I thought it caused by the IT department increasing security. Mine is usually blank but sometimes pulls up random programs like the ones calibration techs use.
Jason,
Calypso 2019 uses a different system (I may be mistaken but I believe it just piggybacks Windows file explorer) for finding and opening files than newer versions such as '22 and '23 so I don't believe this solution will help with your issue. Unfortunately I do not have a suggestion for how to fix your issue, other than the standards: Upgrade to a newer version or service pack(if available), or open a helpdesk ticket for assistance (cic.metrology.us@zeiss.com or 1-800-327-9735)
