Exporting Inspection Updates to another Scanbox
We run the same part on multiple scanboxes. When we have to updated tolerances on the part, we must update them on each scanbox. What is the proper way to export the inspection elements like dimensions with tolerances?
Some of the export file types are causing my custom labels to screw up and have unwanted text in the boxes when I import them to the other machine. I am looking for the correct export file type to pull this off correctly. Thanks.
Are you running them through kiosk? Maybe the project template wasn't saved with the new updates in the program since that file is where all of your tolerancing would come from.
