[66...] Posted January 29, 2021 Share Posted January 29, 2021 ++Repost Frank Büsner++ Hi, is it possible to get information about the core point of one created or fitted element as well as surface patches like splitted cylinders? If it is possible to get this, how to export that with the verified created elements (inspections) as additional information? Thanks Link to comment Share on other sites More sharing options...
[Be...] Posted February 16, 2021 Share Posted February 16, 2021 Hi, I'm not sure what you expext as a core point? But may be the following workaround could help you: restore the point selection from your fitting element and create a best-fit point. If you really want to ensure that special geometric properties (e.g. point must be on the center line of a cylinder) are met you have to do further construction steps like projection of your best fit point on the surface or center line of your fitting element. Regards, Bernd Alpers Link to comment Share on other sites More sharing options...
