Private Messaging is activated - check "How to" on how to disable it Γ—
Export text file
Good morning,
I need to export measurement results to a text file. I get there but I find myself blocked by a limit of 1024 characters. If I use the function several times, it puts them for me but on the line. I wanted to know if we could work around this problem? Either by taking the formula values ​​and grouping them in the same or if we could delete a page break?
I have attached two screenshots to make it a little more understandable.
Thank you in advance for your help πŸ˜ƒ
  • 2 weeks later...
Calypso can do this natively without any code.
Resources -> Results to File -> Set Table File to "On"
then
Resources -> Name for Output Files -> select either "For this measurement Plan" or "For all measurement plans"
Setup the Characteristics table file name definition to whatever you like I suggest something with the program name, and at least the date/time.
Example we sometimes use:
"+getRecordHead("planid")+"_"+getRecordHead("partnbinc")+"_"+getRecordHead("procid")+"_"+getRecordHead("date")+"_"+getRecordHead("time")+"_chr.txt"
