[Je...] Posted September 20, 2023 Share Posted September 20, 2023 . Hey there. Does anyone know what causes the following error to occur at the end of a run when attempting to populate .jpg images (plots): "SavetoMiba failed!" . This error halts generation of measurement results until the "OK" button is pressed. Bonus question: What is a way to disable Calypso's process that removes background color from images during export? . . Link to comment Share on other sites More sharing options...
[To...] Posted September 23, 2023 Share Posted September 23, 2023 Please sign in to view this quote. This error indicates that there was an issue when trying to save or populate a .jpg image into the Miba file. It can be caused by various factors, and troubleshooting it may require examining your specific setup and configuration. Here are some potential reasons for this error: File Corruption: The Miba file or the .jpg image you are trying to populate might be corrupted. Try using a different image or creating a new Miba file to see if the issue persists. File Permissions: Ensure that you have the necessary permissions to save files in the location where you are trying to save the Miba file or .jpg image. File Size: The file size of the .jpg image might be too large for the Miba file. Consider resizing or compressing the image before populating it. Software Compatibility: Verify that the version of Calypso you are using is compatible with the file format of the .jpg image. Updating or reinstalling Calypso might resolve compatibility issues. Hardware Issues: If there are hardware issues with your computer or storage device, it could lead to problems when saving files. Check for hardware errors or consider using a different computer. As for your bonus question regarding disabling Calypso's process that removes background color from images during export, you would typically need to access the settings or preferences within Calypso. The exact steps to do this can vary depending on the version of Calypso you are using, and it may not always be possible to disable this feature entirely. Here are general steps you can follow: - Open Calypso. - Look for a "Preferences," "Options," or "Settings" menu within the software. - Explore the options or settings related to image export or display. - Check for any settings that pertain to preserving background color in exported images. - Adjust the settings as needed to retain the background color. Keep in mind that the availability and location of these settings can vary between different software versions, so consult Calypso's documentation or support resources for specific guidance based on your version. Link to comment Share on other sites More sharing options...
[Da...] Posted September 23, 2023 Share Posted September 23, 2023 Please sign in to view this quote. Tomas, please explain what a Miba file is, never heard of it. Link to comment Share on other sites More sharing options...
[Je...] Posted September 25, 2023 Author Share Posted September 25, 2023 . Please sign in to view this quote. . Thanks, ChatGPT. Thanks. Wrong info. But, thanks 👌 . . Link to comment Share on other sites More sharing options...
[Da...] Posted September 26, 2023 Share Posted September 26, 2023 Fooled, ChatGPT, that explains it. Link to comment Share on other sites More sharing options...
[Jo...] Posted July 8 Share Posted July 8 Please sign in to view this quote. Funny enough, when you ask chatgpt about MIBA errors now. Its like "oh and also here is how to change the background color" for no reason whatsoever other than Jeff asked a bonus question three years ago 😄 😄😄 1 Link to comment Share on other sites More sharing options...
[Je...] Posted July 10 Author Share Posted July 10 Please sign in to view this username. , we are prone to believe what we are taught / trained on. 1 Link to comment Share on other sites More sharing options...
[Sv...] Posted July 13 Share Posted July 13 Has anyone found a solution? I get that error sporadically too—though I haven't seen it for a while now. Still, I'd be interested to know the cause. Link to comment Share on other sites More sharing options...
[Jo...] Posted July 13 Share Posted July 13 This error, for us, has been when writing to the network and something interrupts that process. (Our corporate cybersecurity software HATES calypso programs.) And our solution has been to never use traditional network windows fileshares with calypso. Using sharepoint has some concept of "syncing" files instead of "copying" files that does not upset our IT department Link to comment Share on other sites More sharing options...
[Jo...] Posted 3 hours ago Share Posted 3 hours ago Ironically, we are having trouble with save to MIBA failed errors when generating plots again. Historically this has always gone away when saving files to the C:\ drive instead of to the network. This has started happening recently when saving to the C:\ drive and it is interrupting our pallet runs. 1) Any ideas whats causing this? Could it be our corporate intrusion detection software? Our IT department swears its not but im not convinced... 2) Is there a way to forcibly continue this error so we do not lose our overnight runs? It is heartbreaking and I would rather just be missing one single plot image. The rest of the pallet always completes after clicking OK. Link to comment Share on other sites More sharing options...
