Slot Program Problem
Good Morning.
I am having trouble programming the slot feature on this part. I have taken the features off of the model. Every time I try and check the slot feature my probe always starts to hit the top of the part when I uncheck the single points option in the strategy tab. When I leave it with the check on it starts to check but then it has a collision inside the slot?
Change your clearance data to zero. Change your retract distance using the following formula (Slot width - probe diameter)/2 This should put your entry point at center of slot width.
