142GB scp.log on C drive
Ok... here is a fun one:
I have 2 CMMs -
One has this 142GB "scp.log" file that was (somehow) created yesterday
The other CMM does *not* have any "scp.log" file in the identical location.
Should I presume that I can delete this file safely?
How would I have accidentally created this HUMONGOUS file??
"The action cannot be completed because the file is open in Sentinal Cloud Plugin Service for carlzeissag"
Closed all the programs & re-booted - same result.
AND the file is protected so it cannot be deleted...
In task Manager, under Services you can find the entry for "Sentinel Cloud Plugin Service For carlzeissag".
If its running you can temporarily stop it so you can rename the file.
On my system, this is not running, it shows as "Stopped".
Ahem....I advise against that. Blame Mr. Gates for the system crash but consider this the "you've been warned" statement.
Delete the file. Uninstall the old ZLMT and install the new version from the PORTAL.
Unfortunately, I'm still having the same issue (the scp.log file is 168GB now...) even after uninstalling, deleting the file, and installing the new version.
When I left on Friday I had 50GB of space on the C Drive.
When I got in this morning, I had less than 2GB of space left (due to scp.log file growth)
I upgraded the software on our two CMMs and the Planner station, and only the ACCURA CMM is having this issue...
Keith opens the file and starts reading.....
All work and no play makes Carl a dull boy
  • 2 weeks later...
Still no resolution....
I have Calypso 2021 & GearPro 2023... uninstalling GearPro and loading GearPro 2021 just to see if that fixes the situation before I put in a ticket.
Coincidentally, another (completely new) version of ZLMT was just released. I would attempt this resolution method again. Restart the PC and do not start CALYPSO before uninstall/install. If it does not resolve the issue, please do put in a ticket.
The issue is not likely related to your GearPro installation.
