[Ed...] Posted February 24, 2021 Share Posted February 24, 2021 Hello, Is there possibility to take out .csv file from GearPro! I found the way how to get it for one measurement (one part), but could it be possible to get something in one file let`s say for 10-20 different part measurements? Like in attached file? This .csv file is from gear measuring machine, there I can get out every value of measurement.Ekrānuzņēmums 2021-02-24 105811.jpg Link to comment Share on other sites More sharing options...
[Ro...] Posted March 2, 2021 Share Posted March 2, 2021 Normally you should be able to do this with PiWeb or PiWeb-csv-Export, or does this not fit ? mfg Roy Link to comment Share on other sites More sharing options...
[Ed...] Posted March 2, 2021 Author Share Posted March 2, 2021 I don`t have PiWeb, thats why I`m asking 🙂 Link to comment Share on other sites More sharing options...
[Ro...] Posted March 19, 2021 Share Posted March 19, 2021 csv Export is not possible. Alternative solutions are as Roy mentioned via PiWeb or Q-DAS export interface. Link to comment Share on other sites More sharing options...
[Er...] Posted March 19, 2021 Share Posted March 19, 2021 You can combine the .csv files with Excel. We do this with chr.txt files for copy and paste into our reports. Create a folder on your desktop. Only put the files you want combined in the folder. To the right of the Home tab is the Data tab. Click On the left is Get Data. Click Towards the bottom should be Launch Power Query Editor. Click New Source should be on the right. Click Mouse over File then Folder. Click Select the folder you created. Combine and Transform. Click Delimiter for .CSV is... comma or if .TXT then TAB Click OK Upper left is Close and Load. Click To the right of the Home tab is the Insert tab. Click Pivottable. Click OK. Click Now you just drag what you want to create the table. This is but one path to accomplish this combining of files. Good luck! Link to comment Share on other sites More sharing options...
[Ro...] Posted March 30, 2021 Share Posted March 30, 2021 [list=1]with an XSLT result output a text file can be written concerning to a workpiece with the desired results - and then possibly proceed as Eric Sikora describes it. maybe a text output will follow later, like now the XSLT output but more powerful, so that existing text files, like CSV can be supplemented. Link to comment Share on other sites More sharing options...
[He...] Posted September 21, 2023 Share Posted September 21, 2023 @ErikSikora Could you show me a screen shot where this is set up on GearPro? You say to the Right of the Home Tab is the Data Tab. I don't see a Home Tab in Gear Pro. I can export my OD and RD, and am able to convert that information to get actual points using X,Y, Z, R calculations in Excel from .txt. I want to be able to export my other results like Profile, Lead, and Pitch. My fear is they are getting rid of ListForm, so I need to find an alternate solution here for how we preform our Tooth-To-Tooth calculations. I also want to note, some of these are Helical Gears. Thank you for your time. Heather Please sign in to view this quote. Link to comment Share on other sites More sharing options...
