[Ri...] Posted September 20, 2023 Share Posted September 20, 2023 When saving the CMM Configuration via menus: Miscellaneous System Does this save a specific machine tab that is connected or does this save all machine tabs? I am trying to save a specific machine tab named: RDSXXT Capture.JPGFetching info... Link to comment Share on other sites More sharing options...
[Je...] Posted September 20, 2023 Share Posted September 20, 2023 F1 HELP; C:/Program%20Files%20(x86)/Zeiss/CALYPSO%207.4/userinfo/manuals/en-us/1914244747.html CALYPSO data – scope of backup You can back up the existing CALYPSO installation and program settings to restore them at a different workstation if needed. You can choose between the following data and settings settings in the process: CMM data CMM data and settings (config folder) C:\Users\Public\Documents\Zeiss\CALYPSO {version}\config Virtual CMM C:\Users\Public\Documents\Zeiss\CALYPSO {version}\exchange CMM parameter file C:\ProgramData\Zeiss\CALYPSO {version}\es Templates for PiWeb FlexReporting C:\Users\Public\Documents\Zeiss\CALYPSO {version}\protocol\PiWebTemplates For PiWeb reporting C:\Users\Public\Documents\Zeiss\CALYPSO {version}\protocol\PiWebReportingTemplates for multiple reports C:\Users\Public\Documents\Zeiss\CALYPSO {version}\protocol\protdefinitions User data User settings C:\ProgramData\Zeiss\CALYPSO {version}\users Various settings User-defined toolbar C:\Users\Public\Documents\Zeiss\CALYPSO {version}\toolbar.config CAD Settings C:\Users\Public\Documents\Zeiss\CALYPSO {version}\workarea\CAD-workarea Directory C:\Users\Public\Documents\Zeiss\CALYPSO {version}\data Default Name C:\Users\Public\Documents\Zeiss\CALYPSO {version}\data\config\NamePatternsDefault.txt (File path can be user-defined.) Q-DAS Settings C:\Users\Public\Documents\Zeiss\CALYPSO {version}\qdasconv.con Strategy defaults C:\Users\Public\Documents\Zeiss\CALYPSO {version}\defaults Toolboxes C:\ProgramData\Zeiss\CALYPSO {version}\toolboxes Link to comment Share on other sites More sharing options...
[Cl...] Posted September 20, 2023 Share Posted September 20, 2023 Is this what needs transferred to the planner when programming off-line, and you need the live machines settings? Link to comment Share on other sites More sharing options...
[Ri...] Posted September 20, 2023 Author Share Posted September 20, 2023 Please sign in to view this quote. I guess its safe to assume its all machine tabs. Link to comment Share on other sites More sharing options...
[Je...] Posted September 20, 2023 Share Posted September 20, 2023 Go to the KNOWLEDGE BASE and search "Data Migration". Link to comment Share on other sites More sharing options...
[No...] Posted September 21, 2023 Share Posted September 21, 2023 Please sign in to view this quote. Yes, it saves all machine tabs. The file it creates is a zipped archive, so you can rename the *.set to *.zip and check the content. Keep in mind however that the folder names and structure is a bit different from that of the actual Calypso folder. By the way, it was only yesterday that I found out Calypso 2022 doesn't save the old protform and formplott folders anymore. I know, custom printout is rotting in the grave, but I'm one of many who're still using it, and I'd prefer to be informed by Zeiss when the amount of saved data gets changed. I'm really using this function for my everyday backup routine and I RELY on it saving all the important data it has saved from the beginning. What's a backup worth if I can't rely on what it covers? What's even worse is that it doesn't even bother you with an error message if it can't save a certain file. Happened to me with the stylus database (!) a few years ago. It was only by chance that I discovered the file was missing. Link to comment Share on other sites More sharing options...
