[Jo...] Posted October 15, 2020 Share Posted October 15, 2020 Are there any experienced PC-DMIS programmers who also know Calypso? I am having a hard time with not being able to see the code or see what feature is being measured next. When I have a crash how do I know what feature is being measured? Can I make a correction and pick up where I left off? All of this was much easier with PC-DMIS. Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/ Share on other sites More sharing options...
[Jo...] Posted October 15, 2020 Author Share Posted October 15, 2020 I didn't mean to post this in PCM. Can it be moved to general Calypso? Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-29992 Share on other sites More sharing options...
[Ma...] Posted October 15, 2020 Share Posted October 15, 2020 Near the top of the screen it tells what feature is being measured. When the probe moves, the same message near the top left of the screen indicates the feature it is traveling to. If you can get to training, do so, but the basic class doesn't even cover things like MMC, so advanced is needed, as well. Programming and running from the FEATURES tab will most closely approximate the linear programming method you're used to. Running from CHARACTERISTICS means the features will be measured 'as needed' to fulfill the requirements of the individual characteristic being worked on. In other words, running from Features runs the features in order, running from Characteristics doesn't. Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-29994 Share on other sites More sharing options...
[Jo...] Posted October 16, 2020 Author Share Posted October 16, 2020 Thanks that is helpful Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-29996 Share on other sites More sharing options...
[Jo...] Posted October 16, 2020 Share Posted October 16, 2020 Please sign in to view this quote. To expand on this, a feature will only execute if there is a characteristic requirement. You can make a complete program and compile mini plans for individual operations. This is a huge timesaver over Pc-Dmis in my application. I even have a program that handles, pre heat treat, after heat treat, after plating by utilizing mini plans with different nominals and tolerances for each . Clearance cube navigation is much better in Calypso and will self navigate when not run in a linear fashion. Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-29998 Share on other sites More sharing options...
[Cl...] Posted October 16, 2020 Share Posted October 16, 2020 Create the exact same program using both software's will go much faster with Calypso. Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30000 Share on other sites More sharing options...
[Zo...] Posted December 8, 2021 Share Posted December 8, 2021 Please sign in to view this quote. you can un-check "clear existing results" in start measurement and it will continue where you left off. however, do this only if you have not moved your part, otherwise you are risking a crash Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30002 Share on other sites More sharing options...
[Er...] Posted December 9, 2021 Share Posted December 9, 2021 I also use the Default Printout, normally it runs in the background. As Calypso runs it logs each feature. When running by Feature Order, which I always do, it will tell you exactly what feature was measured last. As Calypso runs the left corner above "CMM" tab displays current and next feature. When Calypso stops that is the first thing I look at and write down. Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30004 Share on other sites More sharing options...
[Er...] Posted December 9, 2021 Share Posted December 9, 2021 An often overlooked resource is getting access to the Zeiss Portal. Inside the Portal are the knowledge base and videos, among other things. Some are free, some have a price. You MUST use a company email address for the Portal. Gmail etc cannot register for the portal. I had to create a new forum account because I used my Gmail address initially. Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30006 Share on other sites More sharing options...
[Da...] Posted December 9, 2021 Share Posted December 9, 2021 Please sign in to view this quote. For e-mail change check -> viewtopic.php?p=10430#p10430 Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30008 Share on other sites More sharing options...
[Er...] Posted December 10, 2021 Share Posted December 10, 2021 Changing it would have been nice. Zeiss Support told me to create a new account. 🙄 Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30010 Share on other sites More sharing options...
[Ia...] Posted December 10, 2021 Share Posted December 10, 2021 Please sign in to view this quote. Same 🤣 Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30012 Share on other sites More sharing options...
[Tu...] Posted September 15, 2023 Share Posted September 15, 2023 Anyone know how to get support for a Hexagon trail base license? Any input would be greatly appreciated? Thanks Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30014 Share on other sites More sharing options...
[Me...] Posted September 20, 2023 Share Posted September 20, 2023 Hi Tuan, Nice talking to you yesterday. Hope you are all set now. Link to comment https://qualityforum.zeiss.com/topic/7188-pc-dmis-to-calypso-transition/#findComment-30016 Share on other sites More sharing options...
