Curve: What is this Guass Filter error?
I have not ran across this issue/error before.
In the attached image, the "purple" text is showing some time of issue/error.
Does anyone know what this means and or what to do to resolve it?
This is in Planner mode.
I think every curve have some type of filtering and evaluation. Here it says error on cmath lib - probably this would go away after restart of cylpso/pc - never encountered it
Hello,
Is it possible that you try to scan a quiet short contour? If yes, then it should be the "Filter" its to short for your filter settings. 🙂
Hope it will work.
