[Wi...] Posted July 18, 2019 Share Posted July 18, 2019 Does anyone know the "how to" on using pi web to export an excel report? Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/ Share on other sites More sharing options...
[fc...] Posted July 19, 2019 Share Posted July 19, 2019 Hi William, There are 2 options for exporting to Excel - either through a Measurement Table or a Characteristic Table. What I typically do is add a button to my report in Designer via the Toolbox tab. Click on the button, go to the Properties tab, and click on Hyperlink. There is a dropdown for a list of available actions. Towards the bottom you'll see Export table data to Excel. Click on this action, it will add it to a list along the left side. Then there is another drop down for either Measurement table or Characteristic table. Depending on the contents of your report, make the right selection here. You can either choose View only (what you see in the table) or underlying values I believe which is all of the information associated to your measurement. I'm going by memory here so the verbiage may be slightly different. You should now have a button in your report that will open a dialog box for you to save to Excel. Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30128 Share on other sites More sharing options...
[Me...] Posted July 26, 2019 Share Posted July 26, 2019 Please sign in to view this quote. Thanks, very helpful Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30130 Share on other sites More sharing options...
[Jo...] Posted January 11, 2020 Share Posted January 11, 2020 Please sign in to view this quote. Is the Excel option available if I do not have Pi Web plus ? Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30132 Share on other sites More sharing options...
[Jo...] Posted January 14, 2020 Share Posted January 14, 2020 Hello John, Yes, you shouldn't have a problem with reporting plus. Best Regards, Josh Smokovitz PiWeb Product Management Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30134 Share on other sites More sharing options...
[Ch...] Posted March 4, 2020 Share Posted March 4, 2020 Hi all I'm new to reporting to excel and piweb in general. This thread was super helpful but is there a way to report multiple sets of results to the same excel file? I'm working on a 60 pc capability study and we want to use our own excel based capability software. It would be awesome if I could get all 60 result sets in the same file where I could copy/paste into our capability sheets. Assume I know absolutely nothing about piweb in your answer. Thanks. Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30136 Share on other sites More sharing options...
[se...] Posted March 6, 2020 Share Posted March 6, 2020 Thank you Laura for the nicely detailed response. I hope this isn't hijacking, but Joshua.... does PiWeb plus require an additional license? It seems it does when I open it up, but was hoping I might just have missed something. Thanks. Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30138 Share on other sites More sharing options...
[me...] Posted April 16, 2020 Share Posted April 16, 2020 Please sign in to view this quote. Dear Laura Jaschke, Can there be visual examples to better understand the subject? Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30140 Share on other sites More sharing options...
[To...] Posted June 19, 2020 Share Posted June 19, 2020 Has anyone figured out a method to export both characteristic data and header data to excel while using PiWeb. The earlier post on this thread don't seem to be quite complete. On a related note, there have been a couple of "how to's" on how to re-position and remove fields from the header section of the characteristics.xlt template file for exporting to excel files in the "pre PiWeb era", but I haven't seen anything on how to add fields. Also, the CMM field is blank but I think this is a newer problem. Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30142 Share on other sites More sharing options...
[Kl...] Posted September 7, 2020 Share Posted September 7, 2020 Short note to get CMM No. Test with ..\data\excel_report\Char.xls. Modification done by CALYPSO 7.0 (2020) Char.xls Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30144 Share on other sites More sharing options...
[Al...] Posted October 29, 2020 Share Posted October 29, 2020 Please sign in to view this quote. Hi Laura , and thanks for this post. I followed your description and was able to export my data. Is there any way to configure the output file? For example, reducing the number of decimals, the original file gives me 5 digits after the comma, 3 are enough for me Thank you Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30146 Share on other sites More sharing options...
[Pa...] Posted April 15, 2021 Share Posted April 15, 2021 Please sign in to view this quote. Hi all, Somehow this is not working on my system (Calypso 7.0.08, PiWeb Reporting Plus). I have created a button and modified the hyperlink accordingly. I'm trying to use this on a table protocol, but the only result I'm getting is an empty Excel file. Any suggestions? Thanks Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30148 Share on other sites More sharing options...
[fc...] Posted April 15, 2021 Share Posted April 15, 2021 Please sign in to view this quote. Table Protocol doesn't contain either a measurement table, or a characteristic table. It's a protocol - a different, unsupported table format. Create a report with either a measurement table, or a characteristic table and add your button. You'll see results. Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30150 Share on other sites More sharing options...
[Ri...] Posted March 13, 2023 Share Posted March 13, 2023 Does anyone have a working template for exporting to Excel? I'm not following something here. I get an XML file with gibberish for data and a PiWeb report with a Characteristic Table overlaying the data. Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30152 Share on other sites More sharing options...
[Ri...] Posted March 23, 2023 Share Posted March 23, 2023 Please sign in to view this quote. Here you go. I built these in 2020.PiWeb Reports.zip Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30154 Share on other sites More sharing options...
[CA...] Posted September 18, 2023 Share Posted September 18, 2023 Good morning and Happy Monday everyone. I am having issues related to this topic and am reaching out for further help. I have tried all the suggestions in this thread and a couple of others, as well as reading through the knowledge base on the portal. I tried downloading and using the table template provided by Richard Shomaker.2 to no avail. If I can get some more details on what I may be missing, it would be greatly appreciated. Running Calypso 2021 (7.2.20) with PiWeb Basic. Do not have Plus or PCM licensing. Thanks in advance for any/all input. Results to File screenshot: Link to comment https://qualityforum.zeiss.com/topic/7214-excel-through-pi-web/#findComment-30156 Share on other sites More sharing options...
