Rotary Table Simulation
Resources, RT functions, feature for RT position. Choose a circle on your center of part.
This is not the proper way to locate the RT in your machine volume however. For that, assuming you have proper machine volume set in simulation probe your actual RT inside diameter. Create a new plan with a circle with these coordinates from machine 0,0,0. Choose this circle for RT position. Now your RT should be properly located in your machine volume.
I have rough CAD model of the R/T if you are interested - better than the simulation model.
Good luck.
