ZEISS CALYPSO 2023 (7.6.04) and PiWeb
Hallo all,
I have a problem after installation ZEISS CALYPSO 2023 (7.6.04).
If I have made a CNC sequence of a test plan, the PiWeb protocol is displayed, what is correct and then closes itself without being asked. What could be the cause? Every now and then the measurement log stays on the screen until I close it. I have no problems with previous CALYPSO versions.
I have the same problem.
However, this only happens when the test plan runs through it for the first time. Subsequent measurements are no longer affected.
Only if again when Calypso is closed.
