Avoid collision using SE and block edges
Hi fellow colleagues,
i have a part, where i have to measure many of them - so close areas - and i need to avoid collision with fixture.
Imagine part shaped like inverted U with fixture magnet from +Y side.
How to simply go from left cylinder to right cylinder using path +Y then +Z then move to +X and -Z?
Now i am using move points, but i think there should be an easier way. If it would be with SG i would be glad, because not everytime i want to +Z
Any ideas? Thanks
"Position Points are not for everyone. Contact your doctor before using position points. Common side effects include irritability, heightened anxiety, and angry coworkers. Some users experienced a rare but life-threatening condition of customer parts resembling modern art after unintended impacts."
Well i did not used that - i meant points in strategy - what i need is after measuring go +Y - now up +Z +X -Z to right position for measuring next part of feature.
I am using this method for avoiding rails while measuring botom plane from -Z. 3001_fa1565bd4f487f92a797726518fb748a.png
Okay, I see. There may be a way to do what you are suggesting from sub-clearance assignments.
I guess I was suggesting that this may be a case where the Use Position Points Only option is warranted, but the risks and process have to be understood.
And using T shaped probe ( 2. and 4. ) - clearance between parts and probes cca 20mm - so i can not increase clearance cube.
But if it would be hard then i will change fixture - short on screw plates to make all needed fixtures.
It doesn't matter if it's in one or more features - i have to avoid that middle fixture - second part is too close for just increase clearance box.
I may not be understanding correctly. I wasn't suggesting increasing the clearance box. I was saying maybe add another (or more) clearance move(s) in your strategy that would retract in the +Y move to +Z then to +X and to -Z to continue measuring.
I use this frequently with a similar stylus configuration. Not sure that would work in your situation.
If you would mind - can you post here how to make those moves? I think it wouldn't work just by adding more clearance data.
Thanks
