Math in PCM
Below is some PCM used in a Result element.
It converts Celsius (C) to Fahrenheit (F).
(getTemperatureCorrection().temperaturePart)* 1.8) + 32)
1. I need to pass this value to a variable: "u_TempStart".
2. How do I use this in a Result element? Can I use it in a Result element?
3. I would like it converted for F.
4. "u_TempStart" is passed to PiWeb. (This part is working without the F conversion) in Post Settings.
setRecordHead("u_TempStart", (getTemperatureCorrection().temperaturePart))
getRecordHead("u_TempStart")
Any assistance is appreciated.
Hello!
I don't think that
work in a result element. In general the pre- or post-settings are meant for assignments.
Why don't you put
in the result element directly?
As far as I know, the temperature of the workpiece is only measured at the beginning of the CNC-start.
We are not using Compensation, we are just recording a temperature value at Start and End of the programs.
I believe you are correct that
will not work in a result element.
I attaching the PCM to features.
In the first temp sensor feature Post settings:
StartTemp=(getActual("u_TempStart").temperature)
StartTemp=formatL(StartTemp,3,1)
setRecordHead("u_TempStart",StartTemp)
The End temp sensor feature Post settings:
EndTemp=(getActual("u_TempEnd").temperature)
EndTemp=formatL(EndTemp,3,1)
setRecordHead("u_TempEnd",EndTemp)
Then in the last feature prior to the End temp sensor: (Forces the temp sensor to run).
getActual("Temp End").temperature
It would be a lot simpler if we could do this. (See attached image).
Climate Change.JPGFetching info...
I assume you use the workpiece senors and not the temperature probe.
You can also use a separate result element with
 readActualWPTemperature("1+2")
for the start and end temperature.
I'm not sure if I'm missing the point here. In my understanding you already successfully converted the value to °F and are also able to assign it to the header variable with setRecordHead.
But why do you want to use setRecordHead() in the result element formula?
I would do all the calculations in the presettings of whatever feature or characteristic and assign the result to a PCM variable:
myTemp=(getTemperatureCorrection().temperaturePart)* 1.8) + 32)
Then use the contents of the PCM variable in the result element or wherever you see fit, by just stating it in the formula:
myTemp
Or am I missing something important? 😕
