[Kl...] Posted September 8, 2023 Share Posted September 8, 2023 Welche Funktion in den userfields.ini hat die Zeile editMode [u_Untersuchungszweck] name=Untersuchungszweck ***************************************** editMode=true ***************************************** runMode=true selectiveList=true selectiveListValues=u_Untersuchungszweck_valueList editable=true Link to comment Share on other sites More sharing options...
[Ma...] Posted September 11, 2023 Share Posted September 11, 2023 I will reply with default comment on userfield.ini ; Now defining the first userfield named u_field1 [u_field1] name=Month ; the text which is shown as the name for the inputfield/list editMode=true ; this field shall be edited while editing the inspection ; Menu Prepare – Protocol Header Parameters runMode=false ; this field shall not be edited before starting CNC selectiveList=true ; it is a list – either a drop down list or a combo box selectiveListValues=u_field1_valueList ; the values for this list are found in the ; profile named “u_field1_valueList“ editable=false ; there’s keyboard input possible for the user – it is a ; combo box (not a drop down list) defaultValue=1 ; the default value to be shown is the value with the ; optionname “1“ Link to comment Share on other sites More sharing options...
