[Da...] Posted September 7, 2023 Share Posted September 7, 2023 I have the side plane selected, and it has become a solid plan which covers up the tapered bore inside of it. Why does this happen and how do I fix it? There have been other times with different programs that it has done this as well and I always just end up starting over because I can't figure out what is happening. Thanks in advance!Capture.JPG Link to comment Share on other sites More sharing options...
[Mi...] Posted September 7, 2023 Share Posted September 7, 2023 CAD-> CAD File ->CAD Model Comparison Click Comparison Select everything Hit Apply Link to comment Share on other sites More sharing options...
[Da...] Posted September 7, 2023 Author Share Posted September 7, 2023 Please sign in to view this quote. That did not change anything. Any other ideas? Link to comment Share on other sites More sharing options...
[Mi...] Posted September 7, 2023 Share Posted September 7, 2023 CAD -> Settings -> Geometry Uncheck " Show 3d geometry Features without CAD Reference" This will fix the issue but it means you won't get a visual representation of things like a recalled 3D Line either. Better to fix the cad comparison issue - sometimes saving the model as .sab, deleting the model in Calypso, then reloading it and redoing the comparison fixes issues like this. Link to comment Share on other sites More sharing options...
[Da...] Posted September 7, 2023 Author Share Posted September 7, 2023 Please sign in to view this quote. Unchecking that box did not fix it either. Can you explain to me what caused the solid plane to appear in the first place? There is only 1 CAD model involved. Link to comment Share on other sites More sharing options...
[Mi...] Posted September 7, 2023 Share Posted September 7, 2023 I would assume it's some artifact in the model then. In the CAD Model Hierarchy you can likely find it and delete it. Link to comment Share on other sites More sharing options...
[Da...] Posted September 7, 2023 Author Share Posted September 7, 2023 Please sign in to view this quote. If it was in the model, wouldn't it have been there from the time I opened it? It was not there at first. I was programing and then it appeared suddenly and I am not sure if it was something I did on accident or what. Thank you for all the help, I am still fairly inexperienced. Link to comment Share on other sites More sharing options...
[Je...] Posted September 8, 2023 Share Posted September 8, 2023 Please sign in to view this quote. . Calypso has the ability to generate CAD entities independent of the imported CAD model(s). For example, there is an option called "Create Geometry" for making simple planes and cylinders. Calypso also auto-generates CAD entities for things like point sets, and temporary entities are created for characteristic evaluation. The "Section" tool under Create Features also populates CAD entities. . . Occasionally, I have noticed Calypso create unwanted CAD entities, such as the plane you are posting about. As mentioned, you can delete these unwanted entities under the "Modify CAD Entities" window. . . Link to comment Share on other sites More sharing options...
