[Ri...] Posted July 7, 2023 Share Posted July 7, 2023 I have attempted to install Calypso v2022 but it fails when installing Net Runtime 6.0. No instructional information, just: Net Runtime 6.0 failed to install. I have also tried to install v2023, with the same issue. In both cases above I aborted the installation of Calypso. Can anyone provide some information on this from your installs? (edit to fix naming)Capture.JPG Link to comment https://qualityforum.zeiss.com/topic/7282-installing-calypso-net-runtime-60-wont-install/ Share on other sites More sharing options...
[Je...] Posted July 7, 2023 Share Posted July 7, 2023 Please sign in to view this quote. Rick, This happens on our computers. It seems to happen when Net Runtime 6.0 is already installed. I usually continue with the installation, and it appears to work fine. I think it's a bug on Zeiss's end. Link to comment https://qualityforum.zeiss.com/topic/7282-installing-calypso-net-runtime-60-wont-install/#findComment-30636 Share on other sites More sharing options...
[DW...] Posted July 7, 2023 Share Posted July 7, 2023 Some thoughts to consider - Are your Windows updates up to date? Does this computer meet the minimum requirements for the .NET 6 Framework? And lastly, have you completed a restart of the computer? I have no idea, but before a call to Zeiss I would check those things first. Link to comment https://qualityforum.zeiss.com/topic/7282-installing-calypso-net-runtime-60-wont-install/#findComment-30638 Share on other sites More sharing options...
[Je...] Posted July 10, 2023 Share Posted July 10, 2023 I had the same problem. Removing all the Net Runtime apps before installing Calypso 2023 did the trick for me. Look for anything with .net or Runtime in it. I overlooked one and got the same error over and over again. Link to comment https://qualityforum.zeiss.com/topic/7282-installing-calypso-net-runtime-60-wont-install/#findComment-30640 Share on other sites More sharing options...
[Da...] Posted September 7, 2023 Share Posted September 7, 2023 Please sign in to view this quote. Thanks for the tip, although I find it strange, I removed all of these -> After CY 2023 install I see only this -> Carl Zeiss, can I expect some problems? Link to comment https://qualityforum.zeiss.com/topic/7282-installing-calypso-net-runtime-60-wont-install/#findComment-30642 Share on other sites More sharing options...
