[li...] Posted September 1, 2023 Share Posted September 1, 2023 I want to use the PCM command to obtain the basic coordinate system on the start measurement page. Can someone help me? I hope to get answers in the community. Thank you first mmexport1693535143665.pngFetching info... Link to comment Share on other sites More sharing options...
[Fl...] Posted September 1, 2023 Share Posted September 1, 2023 Hi Liang, i think this should work: getStartSetting("baseSystemRealName") Regards, Florian Link to comment Share on other sites More sharing options...
[li...] Posted September 3, 2023 Author Share Posted September 3, 2023 Florian Leitner Thank you very much for your answer. I am in calypso 6. Version can execute the above code, but in 5. Version 2 does not work on the machine. Are there any code functions compatible with lower versions of the implementation? Link to comment Share on other sites More sharing options...
[Mi...] Posted September 4, 2023 Share Posted September 4, 2023 Maybe this works: baseSystem().machine.inspection.baseSystemIdentifier Link to comment Share on other sites More sharing options...
[li...] Posted September 4, 2023 Author Share Posted September 4, 2023 Michael Krauskopf, thank you very much for sharing the code. It can run smoothly on the 5.2 machine。If my basic coordinates are selected for manual operation, the result is # base. Where did you find all your thank you PCM codes? I also wish I could know more Link to comment Share on other sites More sharing options...
[Mi...] Posted September 6, 2023 Share Posted September 6, 2023 Hello, this is some non-documented code. You can search the forum for more code snippets. Link to comment Share on other sites More sharing options...
