Reporting Temperature from an RST-T Sensor (VAST)
I would like to have the temperature of a part reported in my PiWeb reports, I don't want Coefficient Compensation, just the temperature.
I have two features setup:
Temp Start
and
Temp End
How do I add a characteristic?
I found this will report the temperature (Converted to F).
(readActualWPTemperature()* 1.8) + 32)
Now I need to pass this to a variable called "u_TempStart" and "u_TempEnd".
I am using a Result element for each.
Edit:
I believe this is only data of sensor "1" and "2" internal to the CMM and not the temperature probe.
There is a PCM string of "temperatureProbe", but I am uncertain of its use.
I also found this code, but it doesn't seem to work.
getTemperatureCorrection().temperatureProbe
I would have thought it would report "20" like the other command reports instead of "9999".
According to the "Mimir" program from this forum, the correct syntax may be:
getTemperatureCorrection().temperaturePart
This returns the value "20".
I can't confirm yet if it a direct reading from the temperature probe.
