How to add dialog widget in script?
Is it possible to add widgets to a dialog programmatically?  I'm looking to add a checkbox for each item in a list.
Thank you!
Matt
Hello Nanno,
Thank you for the quick response!  I am looking to add widgets to the dialog using the script.  The number of checkboxes will be different each time.  I did not see anything to do that in the FAQ, or using dir() and .__doc__ on the gom classes.  After looking at this a bit further, I am thinking there is no built in way to do this.  Dealing with the rows and columns would make it very difficult. But please let me know if I am missing something.
I am going to try creating a dialog with a few checkboxes and then using the resulting xml as a starting point.  I can modify and add to the xml string and then pass this as the content to the create_user_defined_dialog function.  I will update to let you know how it goes.
Thank you again,
Matt
