Not sure how to do this one...
B cylinder, C is the intersection diameter, A is the plane.
Best fit bore pattern, view tolerance, add MMB to datums ,free to rotate and translate ......
Wonder without true position then what you are using...
True position is my bread and butter...
It's a little odd because Datum B is controlled perpendicular to Datum A. As tertiary, Datum A can only be asked to constrain the last degree of translation. Datum A exists perp. to Datum B, but the two degrees of translation on Datum A's space axis are already constrained by B.
