[An...] Posted August 31, 2023 Share Posted August 31, 2023 Using a formula I can get the date when a probe was qualified but result element will not take a string. I tried using text element but that does not work in PiWebb for some reason. Anyone have an alternative? Right now my ideas are: In the formula somehow convert the 8/30/2023 string into a formatted number Use another type characteristic I don't know about to output the date Use Piwebb to get the probe qualification date if possible. Link to comment Share on other sites More sharing options...
[Ro...] Posted August 31, 2023 Share Posted August 31, 2023 What version of Calypso are you using? In 2021 the ability to upload text elements, into PiWeb, was eventually added in. If the box is already selected, you may need to unselect, and then reselect it, for it to work. That's what I ended up having to do, when I was trying to get it to work. Link to comment Share on other sites More sharing options...
[An...] Posted September 1, 2023 Share Posted September 1, 2023 Could use the comment section of a Group in lieu of a Text Element, assuming you had some other characteristics to group together to output your information. viewtopic.php?p=28098#p28098 Link to comment Share on other sites More sharing options...
[Ri...] Posted September 1, 2023 Share Posted September 1, 2023 Please sign in to view this quote. You can use this to break down time. (Courtesy of users from this forum). nTime=time() nHour = strElement(1,":",nTime) nMinute = strElement(2,":",nTime) nSecond = strElement(3,":",nTime) nTimeFile = nHour+nMinute+nSecond Example: 12:30:00 PM Will look like this: "123000 PM" Example of a file name for Excel adding the time at the end: Ruby Head_Rev 2_Op 60_M0060-No_82.7_R37_H25035_2023-7-29_92331 AM.xls viewtopic.php?t=11497 Link to comment Share on other sites More sharing options...
[An...] Posted September 1, 2023 Author Share Posted September 1, 2023 I got the text elements into piweb but so far have only been able to get a 0.0 measured result instead of the string that is in the characteristic itself. Link to comment Share on other sites More sharing options...
