[Ri...] Posted August 30, 2023 Share Posted August 30, 2023 I don't know how this happens, but it happens a lot. Somehow, the MasterProbe axis get mixed up. I had Zeiss setup the laptop with Planner so I had reliable visual and geometric relationships for collisions. After I had to re-create machine tabs, this happens. See image. How do I fix it without deleting the tabs?Capture.JPG Link to comment https://qualityforum.zeiss.com/topic/7320-masterprobe-setup-in-planner/ Share on other sites More sharing options...
[Je...] Posted August 30, 2023 Share Posted August 30, 2023 Please refer to the ZEISS PORTAL KNOWLEDGE BASE Link to comment https://qualityforum.zeiss.com/topic/7320-masterprobe-setup-in-planner/#findComment-30826 Share on other sites More sharing options...
[Ri...] Posted August 30, 2023 Author Share Posted August 30, 2023 When you create a MasterProbe in Stylus System Creator, it always has a R0.0 Stylus tip (VAST and RDS XXT TL3) Problem with the Knowledge Base information, it doesn't seem to apply correctly. And there is no information for VAST heads (Which also uses a R0.0 stylus). Adjusting the R value and I can get the VAST head to appear OK. The Z values are wrong for RDS XXT TL3. When I use what the PDF file generates (188.102), Z axis appears to be OK. KB is "192.889", which is quite a bit off. With Z at 188.102. Z axis appears to be OK. Y axis appears to be OK. X axis is hard to tell because the viewing aspect ratio is off (Sphere looks like an egg). Adjusting the R value helps.RDSXXT TL3 Y axisJPG.JPGRDSXXT TL3 X axisJPG.JPG Link to comment https://qualityforum.zeiss.com/topic/7320-masterprobe-setup-in-planner/#findComment-30828 Share on other sites More sharing options...
[Ri...] Posted August 31, 2023 Author Share Posted August 31, 2023 This is what we deal with... At Z Down (A0B0). See image: Capture Z down.JPG At A0B90. See image: Capture A0B90.JPG As long as the probe is A0B0, its all ok. Once you articulate it in any angle... 🙄Capture Z down.JPGCapture A0B90.JPG Link to comment https://qualityforum.zeiss.com/topic/7320-masterprobe-setup-in-planner/#findComment-30830 Share on other sites More sharing options...
[To...] Posted August 31, 2023 Share Posted August 31, 2023 Rick, Have you tried running through the reference sphere position or stylus qualification. Many years ago, I recall have a similar issue that went away after performing the qualification sequence. Link to comment https://qualityforum.zeiss.com/topic/7320-masterprobe-setup-in-planner/#findComment-30832 Share on other sites More sharing options...
[Ri...] Posted August 31, 2023 Author Share Posted August 31, 2023 Please sign in to view this quote. I have completed all that, including a "Fitting" with the MasterProbe. Everything comes up "OK". I viewed the qualifications (CAA) and the X, Y, Z and angles are all correct. Link to comment https://qualityforum.zeiss.com/topic/7320-masterprobe-setup-in-planner/#findComment-30834 Share on other sites More sharing options...
