Toggle visilbity
Can you please help me with the toggle visibility button.
i am using the Select Through Surface command and then i Increase the Selected Area on the neck of the flange. I copy the selected area and its created under Clipboard's area.
i am trying to hide the neck of the flange (and see the boundaries of the inner part of the flange) but i cannot do it although i click the toggle visibility button. Please have a look on the video which is attached and advice what am i doing wrong
717093455_gomissue_2.wmvFetching info...
Edited
better description of the problem
  • 2 weeks later...
Hello,
for some reason I can't download the video. Could you reupload it or contact your local distributor with the problem?
Regards,
Nanno
