Program Info
Info for above quote.
"dmesn 000000"
This is the CMM serial number, "000000" is Planner (Offline).
If you keep a list of CMM serial numbers (last 6 digits, you should be able to track it).
"operid" If you use names for operators, this will be where to find that info, otherwise it may say "Master" or "User", etc.
"dmeid Prismo"
This is the type of CMM.
Another file to look at is "protheadpara".
https://qualityforum.zeiss.com/topic/7346-program-info/#findComment-30930
