[Ke...] Posted August 29, 2023 Share Posted August 29, 2023 If I have a measurement plan on file, and I wanted to know who wrote it or which plant it came from originally: Is there a file within the measurement plan that I can open to see who wrote the program or (at the very least) which CMM it was written on, as that would narrow it down. Link to comment Share on other sites More sharing options...
[Cr...] Posted August 29, 2023 Share Posted August 29, 2023 Resources - Measurement Plan Information. That will give you the operator and CMM the program was created on. Link to comment Share on other sites More sharing options...
[Ke...] Posted August 29, 2023 Share Posted August 29, 2023 Check in the startfile file in the program folder with a text editor (I prefer notepad++ for this), some of that information may be in there, depending on if they wrote it offline or on machine, if they were logged in as a unique user or master, etc. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 29, 2023 Share Posted August 29, 2023 Please sign in to view this quote. Info for above quote. "dmesn 000000" This is the CMM serial number, "000000" is Planner (Offline). If you keep a list of CMM serial numbers (last 6 digits, you should be able to track it). "operid" If you use names for operators, this will be where to find that info, otherwise it may say "Master" or "User", etc. "dmeid Prismo" This is the type of CMM. Another file to look at is "protheadpara". Link to comment Share on other sites More sharing options...
