[Wi...] Posted August 25, 2023 Share Posted August 25, 2023 Hello everyone, I measure a tool with a test plan. After the characteristics are measured in the CNC, further characteristics are measured manually. Finally, I programmed a program stop, with the instruction to take the tool from the CMM and measure other characteristics with a special measuring device. I enter these measurement results manually in the result element under result input. Everything works. Now my problem is coming. I would like to have the following order in the PiWeb measurement protocol: - measured values CNC process, - then measured values from special measuring device, i.e. not CMM and - finally measured values measured manually on CMM. This method would mean that the software should "remember" the manually measured values CMM. These measured values should be written in the measurement protocol after the measured values of the special measuring device. Is there a solution ? Link to comment https://qualityforum.zeiss.com/topic/7374-sequence-of-the-test-elements-according-to-the-measurement-process/ Share on other sites More sharing options...
[Ju...] Posted August 25, 2023 Share Posted August 25, 2023 Maybe try including the measuring device/style in the characteristic name(s)? 1 - CMM_CNC 1 - Special_Device 1 - CMM_Manual Link to comment https://qualityforum.zeiss.com/topic/7374-sequence-of-the-test-elements-according-to-the-measurement-process/#findComment-31054 Share on other sites More sharing options...
