Polynom Surface
Hi,
How to export polynomial surface in gom inspect, I am not able to export this surface from gom inspect it shows some error.
Hi Manoj,
In which format is the export required?
The polynominal surface itself can not be exported. But you can tessellate it (CONSTRUCT>Surface>Tessellate Geometrical Element) and export this surface instead.
Hope this helps.
Cheers, Sergio
Hi Sergio,
Good day!
I need this as IGES Format,
I have created tessellate on that polynomial surface but still, I can't export that tessellates surface.
Just for your info, I am using GOM 2019 free software version.
Hey,
The IGES format exports only standard geometry elements like circles, lines, points etc. or sections.
If you want to export mesh/tessellated structures you can either use the STL or G3D file format.
If kind CAD model is required the mesh has to be converted in a Reverse Engineering Tool like Zeiss Reverse Engineering.
Hi Christine,
Thanks for the info, But is it possible to export polynomial surfaces? Get it like standard geometry
If possible it would be great and time-saving for creating a CAD model from STL data.
