[Da...] Posted August 23, 2023 Share Posted August 23, 2023 I recently needed a self centering point at a 45 degree angle to the machine axis. I'm running 2023 and I haven't used SCpoint for quite some time. The 45 degree point seems to snap the vector angle to machine axis every time I try to touch off... Link to comment Share on other sites More sharing options...
[Ke...] Posted August 23, 2023 Share Posted August 23, 2023 Please sign in to view this quote. Once upon a time I had an excel spreadsheet that did the calculations. There are a few vector calculators searchable online. I believe I usually set up a secondary alignment - set the point to that and just set it to "Probe In Normal Direction", for odd angles. Link to comment Share on other sites More sharing options...
[Cl...] Posted August 23, 2023 Share Posted August 23, 2023 Link to comment Share on other sites More sharing options...
[Da...] Posted August 23, 2023 Author Share Posted August 23, 2023 Clarke, thanks for the vector angle on the 45, but, how is that figured? Link to comment Share on other sites More sharing options...
[Cl...] Posted August 23, 2023 Share Posted August 23, 2023 If you mean where do the vector values come from, you enter them. This spreadsheet will calculate them for you. It was designed originally for circles, but I think it will work for your application. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 23, 2023 Share Posted August 23, 2023 I got this from this forum some time ago. Direction Vector Calculator.xlsFetching info... Link to comment Share on other sites More sharing options...
[Cl...] Posted August 23, 2023 Share Posted August 23, 2023 Please sign in to view this quote. Thats a powerful spreadsheet, thank you! Link to comment Share on other sites More sharing options...
[Jo...] Posted August 23, 2023 Share Posted August 23, 2023 Stop doing it the hard way. RESOURCES>FEATURE REPRESENTATION directly enter angle change.JPGFetching info... represent.JPGFetching info... Link to comment Share on other sites More sharing options...
[Is...] Posted August 24, 2023 Share Posted August 24, 2023 viewtopic.php?p=29138#p29138 fml.pngFetching info... Link to comment Share on other sites More sharing options...
