[To...] Posted August 17, 2023 Share Posted August 17, 2023 I have a 2D Curve and would like to know the best method for extracting the Max/Min Deviation Points (as seen in the Form Plot of the Line Profile Characteristic) from the ASCII File. I am trying to find the exact XYZ coordinate location of the deviation point on the screen in the software relative to the coordinate system. How? I Utilize the Accura II Thank you in advance! Link to comment Share on other sites More sharing options...
[Ma...] Posted August 17, 2023 Share Posted August 17, 2023 I think you can use this way: create theoretical point use formula for X,Y,Z nominal: getActual("CURVE name").xMaxDev ( can be used x|y|z and Max|Min ) Link to comment Share on other sites More sharing options...
[Cl...] Posted August 17, 2023 Share Posted August 17, 2023 I wonder if you pull the curve into a Curve Form and choose "Points List"? Not at my software now, so can't try it out. Link to comment Share on other sites More sharing options...
[Je...] Posted August 22, 2023 Share Posted August 22, 2023 To do this within CALYPSO requires PCM. PCM can be used to review the ASCII file as well. To do this with the exported points list without PCM would require some Excel work or batch files and would need to be done independent of CALYPSO Link to comment Share on other sites More sharing options...
