Editing the save path
Hello.
I have a question about the path to save reports. Namely, I mean, is it possible to select, for example, only the first 10 characters from the syntax: getRecordHead("startcomment").
Sample edit path.
"C:\...\"+getRecordHead("planid")+"_"+getRecordHead("startcomment")+"_"+getRecordHead("date")+"_"+"("+getRecordHead("time")+")"+"_"+getRecordHead("order")+"_"+getRecordHead("startcomment")+"_"+getRecordHead("palletid")+"_"+getRecordHead("partnbinc")+"_"+getRecordHead("vda_version")+".pdf"
Regards.
Yes, it is possible but you have to use string editing PCM commands to do this.
mid(getRecordHead("dmeid"),1,10)
Starts at char 1st and grabs 10 chars.
