[Ja...] Posted August 7, 2023 Share Posted August 7, 2023 I have a program that outputted the information to PiWeb once, but has stopped doing so since. I ran other programs and they output to PiWeb from this computer, and we tried another pc with Calypso and it didnt work there either. The settings are turned on to output to PiWeb via the Resources>Results to File menu. I have included the zip file of the program as well as a copy of the Upload Options we are using. It is an "Offline" upload options, but again, it does work with other programs, just not this one. We are running Calypso 7.4.04.UploadOptions.zip3742 M1 G2.zip Link to comment Share on other sites More sharing options...
[Ri...] Posted August 7, 2023 Share Posted August 7, 2023 Works for me. Are you sure it isn't outputting to PiWeb? Is your PiWeb Reporting Plus setup to pull from the correct directory? If you have only one version of Calypso installed, it should be to "C:\Users\Public\Documents\ZEISS\CALYPSO\workarea\PiWebReportingDatabases", but if you have multiple versions of Calypso installed it should point to your specific version "C:\Users\Public\Documents\ZEISS\CALYPSO 7.4\workarea\PiWebReportingDatabases" Link to comment Share on other sites More sharing options...
[Ri...] Posted August 7, 2023 Share Posted August 7, 2023 I'm sorry. I see you are referring to PiWeb Server The PiWeb Export you have turned on is for the old method of uploading data into the PiWeb Server. It has been replaced with PiWeb Synchronization. This is found in Results to File - PiWeb Reporting - Configuration - Synchronisation after measurement run. You will first need to setup the Database Extension though found in Extras - Settings - Environment - PiWeb Reporting. Link to comment Share on other sites More sharing options...
[Ja...] Posted August 7, 2023 Author Share Posted August 7, 2023 We don't have that setup as we use different variables, etc. it was a pain trying to get it to work late last year, and we decided to just use this option for now. All of out other programs that do export to PiWeb are using the same format, but for some reason this one is not outputting. Here are some screenshots of the file that is working correctly. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 7, 2023 Share Posted August 7, 2023 Please sign in to view this quote. The Sychronization is superior to the former Upload Options in every way. It natively brings in your header variables, so that you don't have to rely on userfields.ini anymore. I haven't used the UploadOptions format in a few years. I promise it's not too bad, and I'd love to help you transition over. Laura might be able to help out, but it's possible that you may have to reach out directly to Zeiss. The only suggestion I would have it ensure that you have the same version of PiWeb installed across all systems (server, and local PCs). Link to comment Share on other sites More sharing options...
